Springboard crash
motojavs
Dec 14, 2008
49
I have a iPhone 3G and the other day the springboard crash and it had a strange black screen with symbols almost like an old video game.
I was wondering if this is common when you jailbreak your phone or what can be the reason? Once I reset the phone, everything when back to normal until yesterday when all my calls rang once and went to voice mail and text messages were not getting through.
Thanks in advance for your help.
fc97accord
Oct 2, 2008
96
Vancouver
Did you try to restart your phone again and see what happens? Also try a softboot (holding the home and power button until the logo come on again).
Or maybe you have to rejailbreak.
What you experienced was a "Safe Mode" that the iPhone is kicked into when the Springboard has crashed, delivered by MobileSubstrate. It doesn't mean anything - it's just a way to prevent damage to the filesystem. The "strange black screen" you described is just a wallpaper called "Sad iPhone" - a play on the "Sad Mac" screen - that appears along with Safe Mode.
nobopyon
Jul 11, 2008
393
Dallas, TX
I freaked out when I first got "sad iPhone", but now, i think they are quite charming instead... (not get into safe mode, but the "sad iPhone" LOL).
I get "safe mode" time to time... but pretty rare it happened to me
28,365
5,506
I had it happen once when I was respringing after changing the theme. I think it happened because I pressed the home button while it was trying to respring. Anyway, I resprung after going into safe mode and everything was fine.
Feb 9, 2009
this just happened to me and all my apps don't work anymore.. what should i do?
28,365
5,506
Have you tried rebooting it by holding the home and power buttons and ignoring the slide to turn off? If that doesn't work you may need to restore it to factory settings and rejailbreak.
monosokis
Aug 14, 2009
iPhone resprings on incomming call
I have a bigger issue than that. There are 2 particular phone numbers which always respring my iPhone when it called. I can't tell when these numbers call me from the screen, all I see in it is the spindle running.
I tried restore my iPhone then re-jailbreak but same thing happens. Please advice ...
monosokis
Aug 14, 2009
I found out the issue and it had to do with my previous backup profile. So after I restored to a new iPhone settings, everything goes back to normal. However, I am curious to know what really caused the issue with my original profile ...
DaBears34
Sep 9, 2009
crashh!
What you experienced was a "Safe Mode" that the iPhone is kicked into when the Springboard has crashed, delivered by MobileSubstrate. It doesn't mean anything - it's just a way to prevent damage to the filesystem. The "strange black screen" you described is just a wallpaper .
-- well i have the iPhone 3g and when i turned my phone on its went to the sad iPhone wallpaper. and when i try to access cydia it wont go to it.
What should i do?:mad:
28,365
5,506
Have you tried rebooting?
DaBears34
Sep 9, 2009
--if you want to restore your iPhone you have to do it through iTunes right?
sallyb
Jan 29, 2010
hi can anyone help? i was playing with my iPhone 3g os and a message came up saying springboard has crashed. it gives you three options. restart,ok,help. i have tried each one and the message keeps coming up. does anyone know how to exit safe mode. thanks guys :(
iBanana
Jan 15, 2010
713
United States
you hit restart. if it continues reboot your phone. something you downloaded recently sounds like its not playing well with other downloads
sallyb
Jan 29, 2010
hi there i have done that already. but keeps coming back to seem message. ive re-booted as well and still comes back to same message. should i restore to factory settings and then re-jailbreak not sure what to doont want to make things worse
sallyb
Jan 29, 2010
i downloaded intelliscreen and since then its crashed. i have deleted it now but still same message looks like its going to have to be restore to factory settings and then jailbreak again unless someone has another answer but thanks for ure input
iBanana
Jan 15, 2010
713
United States
you unintalled it and did a reboot? maybe try a reset by holding down the power button and home button at the same time until the Apple shows up on the screen.
iBanana
Jan 15, 2010
713
United States
something just doesn't play right with other packages that she's downloaded. i had some that don't work for me at all and always sent me into safe mode and others never had the issue. restoring is really jumping the gun in this case imo
