Springtomize 3 Released with iOS 8 Compatibility
iphonewarrior
13,847
701
Springtomize 3 has been released!
For lovers of multiple tweaks like Five-Column Springboard, Shrink and much more then this app is for you. It houses many tweaks/mods all under one roof.
iphonewarrior
13,847
701
Springtomize 3 has just received a small update, bug fixes etc.
iphonewarrior
13,847
701
Apart from the landscape dock mix up issue (which has been fixed) it's been bang on so far.
iphonewarrior
13,847
701
Do the scroll and start on page functions still work (I don't remember the exact function names)?
Just to make sure I understand correctly, by Scroll do you mean the barrel effect where the icons move differently when changing pages? What do you mean by start on page?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Look in the Infinidock settings to see the various options. I don't have it installed right now.
Kadelic
Jan 4, 2010
4,938
1,645
Dallas, TX
I love this tweak, including the multiple animations for paging between home screens and being able to set custom badge colors. My only request so far is that Icon labels and Folder labels should be separated into distinct entities. As it stands now, if you hide labels for your home screen apps you also hide them for your folders.
iphonewarrior
13,847
701
I don't have Infinidock installed - Springtomize does have the ability to add up to ten icons into the dock, with cover flow. I didn't see a settings for what you mentioned.
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Upon preliminary testing, I find that my two or three separate tweaks do a better job of what I want to accomplish..
Springtomize doesn't hide my app labels and doesn't hide the folder blur. Its acceleration function is a joke. Maybe it's a problem peculiar to my phone.
I'll reinstall it later and give it another go.
iphonewarrior
13,847
701
Do you already have another app accelerating your animations? I'm using Springtomize to hide my labels and it's working fine?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
The folder transparency setting works fine, but does not remove the folder background on the folder icon. I am also having a problem with the landscape setting while I am set to 5 x 8 icons on the portrait home screen.
Rick
The folder icon transparency doesn't work for me, either, so I used HiddenSettings8 for that.
If you removed your dock background you'll have issues in landscape.
I'm also getting this bizarre behavior when Springtomize 3 is enabled. When I go to the last page on my Plus (I only have four), go into landscape mode and return to portrait, the previous page (only this page!) looks like this:
I have to pop into landscape and back again or hold down on an icon until they wiggle to return the page to its proper behavior. Odd.
coop1701
Jun 30, 2007
899
114
43
It restarts my Phone every time I make a change. I have no idea why.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
This tweak still needs updating. The hide status bar icons is not working. I have to use hideme8 to do this. It stinks to need two tweaks that almost do the same thing.
