Square trade.
Josh Yates
Jul 14, 2007
563
32
Orion, MI
Depends...if you can get AppleCare + and you live around an Apple Store...you may want to consider it. Taking it in to an Apple Store is much easier than sending it off to SquareTrade and the deductible is the same. However, if you're going to have to put more $$$ into the AppleCare + than what you currently have...it may not be worth it.
flightmedic
Jun 21, 2009
397
23
Wichita Falls, Texas
Isn't there some stuff that Square-Trade will cover that AppleCare won't?
I use Worthington Ave Group which also covers theft also (not sure if Square Trade does or not).
Jim
Josh Yates
Jul 14, 2007
563
32
Orion, MI
Not really...appleCare+ now covers accidental damage for 2 years as well. $99 for two years...two damage claims with a $49 deductible. SquareTrade has the same deductible. Only thing is you have to send it in to SquareTrade, when you can just walk into an Apple Store for replacement. That and the actual warranty is extended for two years...so if a technical thing goes wrong during that time, it's replaced for free...not to mention the added customer support.
If you want another option, Zagg (makers of InvisibleShield) just came out with their own version of a warranty. About the same as SquareTrade & Apple, though.
Jeff Berry
Apr 27, 2012
Protectyourbubble.com is another option as well. It covers the same as SquareTrade and AppleCare but also includes coverage for theft and loss. $7.99 a month - cancel any time.
