SSH Not Working iPhone 3G 2.0.1
Sep 29, 2007
348
I have had problems with my iPhone 3G and SSH for quite some time now. I know what to do but I have tried about everything and nothing is working.
I have a White 16Gb iPhone 3G Jailbroken 2.0.1 on a Macbook Pro running Leopard and I usually use Fugu or Terminal to access my iPhone using SSH but I just keep getting these errors:
Proof I Installed it and have Reinstalled it many times:
As you see it is installed and I have toggled it on many times and even have done a restore but whenever I try to access it using Fugu or Terminal I get the same thing..it usually takes about 2 mins and then it shuts off.
Yes my iPhone is on and I turn off screen lock so it stays active the entire time.
Sep 29, 2007
348
anyone? I did another restore and nothing
g33k1
Sep 6, 2007
61
San Antonio Tx
did you check to see if the ip address has changed since the update?
ZR_Yancy
Jul 11, 2008
3,982
737
Have you tried using something like Cyberduck?
I use Cyberduck and Terminal; they both work fine for me. Try using BossTool to turn SSH on/off, and make sure you're typing the right commands in Terminal. It should all go like this:
You type: ssh root@ipaddress
Terminal: password:
You type: alpine (this will be masked)
Terminal: localhost:~ root#
Witness
Jun 18, 2007
1,471
26
Miami,Florida
im using cyberduck on my mac and it works perfectly fine, maybe you should try it
Sep 29, 2007
348
Terminal: password:
Ill try cyberduck when my iPhone starts cooperating but I am doing the commands right as you see here it just times out:
