SSH Only
Justin
Mar 6, 2007
71
Is there any way to only have SSH avaliable on my phone? I jailbroke it, installed a few toys, then the phone started acting kinda goofy. Programs would shut down, some not even open. The phone would lock itself when i attempted to open programs... it got kind of unstable.
I want to completely reset everything, but I like being able to manually change a few icons, my slider, ringtones, etc. manually through ssh...
anyway to do that without jail breaking the phone or installing any other software? I'm under the impression I will have to have "installer" and BSD systems...
CoOoOoL
Dec 2, 2007
60
hi dear,
maybe if you tried to syncro your iPhone with the pc and u go to iTunes ,chk new device iPhone and chk the icon return to prev update
i hope it well solve your problem.
thx
termleech
Sep 7, 2007
1,154
McPherson, KS
You need to jailbreak the phone at minimum to have SSH installed. You don't need to install anything else as the new jailbreak for 1.1.2 (when you upgrade from 1.1.1) installs SSH.
