SSH toggle has vanished from SBSettings
O_mer
Jul 3, 2013
Hey everyone,
Something really strange happened to me the other day.
When i entered the DropDown window of my SBSettings to see the toggles, i saw that the "SSH" toggle is not there, altough it is turned On in the settings for the DropDown window.
I have tried to turn it off, respring, turn it on and respring and it is still not there.
I have even tried this process with rebooting.
I thought about reinstalling openSSH from cydia but I don't think that I need to because when I first installed SBSettings, the SSH toggle was already there, except that SSH needed to work only if I install openSSH, so I don't think that reinstalling openSSH will help.
Another thing that came up the day before this issue was that cydia failed to fetch something from the source [Cracked app repo removed] repo.
I am not sure if there is a connection between the "failed to fetch"thing and the SSH toggle missing, but I'm writing it down to let you know just in case.
I really appreciate your help and time reading this.
This issue is weird and a bit frustrating at the same time.
If there is something I wrote you didn't understood, post a message and I will explain more.
28,365
5,507
Thread moved to the iPhone Jailbreak subforum.
Please refrain from discussing cracked apps or software used to install them. We don't support app piracy.
I would try reinstalling OpenSSH.
O_mer
Jul 3, 2013
I am sorry about posting here...
Thank you very much for all, reinstalling worked :)
Dec 15, 2008
5,386
340
Pensacola, FL
I am having an issue with SBSettings as well, but a little different. My WIFI toggle continues to go off on its own although I am still on WIFI in the iPhone settings. I toggle WIFI on but then once I exit SBSettings, it goes back off. To fix this, I have to respring. I have already tried reinstalling SBSettings.
