StickyBanners needs frequent reinstalling
iphonewarrior
13,847
701
What other tweaks do you have installed that could potentially cause you issues. More specifically tweaks which effect notifications etc?
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
From AppInfo:
Packages
7-zip (POSIX) - 4.57-3p
Activator - 1.9.2~beta2
AdvancedSettings8 - 1.0.1
Agape - 0.0.1-86
Alkaline - 1.3
AppInfo - 1.6.2
AppList - 1.5.9
APR (/usr/lib) - 1.3.3-2
APT 0.6 Transitional - 1:0-23
APT 0.7 (apt-key) - 0.7.25.3-3
APT 0.7 Strict - 0.7.25.3-8
APT 0.7 Strict (lib) - 0.7.25.3-13
ayecon (iOS 7+) - 1.1.1
ayeKit - 1.0.1
Base Structure - 1-4
basic-cmds - 48-2p
Berkeley DB - 4.6.21-4p
BigBoss Icon Set - 1.0
Bloard - 0.0.9
BlueBoard - 0.0.3-12
Bourne-Again SHell - 4.0.44-15
Browser Changer - 1.16-5
BundleIDs - 1.0-7
bzip2 - 1.0.5-7
CallConnect - 0.0.1-11
CCSettings for iOS 8 - 0.0.6-113
ChargingHelper for iOS 8 - 0.6.4-1
Core Utilities - 8.12-12p
Core Utilities (/bin) - 8.12-7p
CrashReporter - 1.8.3-1
Curiosa - 0.9~beta3
Cydia Installer - 1.1.16
Cydia Substrate - 0.9.5101
Cydia Translations - 1.1.12
Darwin Tools - 1-4
Debian Packager - 1.14.25-9
Debian Utilities - 3.3.3ubuntu1-1p
DetailedBatteryUsage - 1.1
Dexterity 3 - 1.0
Diff Utilities - 2.8.1-6
Disable iOS Swipe Back - 1.0.1-2
diskdev-cmds - 421.7-4
DoubleTapToSleep - 1.0-1
Erica Utilities - 1:0.4.2
f.lux - 0.998
f.lux Flipswitch - 0.3
FakeClockUp - 0.5-6
FBNoNeedMessenger - 1.0-3
file-cmds - 220.7-3
Find Utilities - 4.2.33-6
Flipswitch - 1.0.6~beta2
FolderEnhancer (iOS 7/8) - 2.4.2.2
Gawk - 3.1.6-2p
GNU Privacy Guard - 1.4.8-4
grep - 2.5.4-3
gzip - 1.6-7
HASHBANG Productions Common - 1.1
Hide Labels - 0.0.1-10
HideMe8 Lite - 0.0.3-2
iCleaner Pro - 7.3.2
Icon Renamer - 1.2.1
IconBundles - 0.2-1
IconSupport - 1.9.4-2
iFile - 2.2.0-1
iLEX R.A.T. & RESTORE - 2.2-22
Instagram ++ - 1.2r-59
iOS Firmware - 8.1.2
iPhone Firmware (/sbin) - 0-1
Jetslammed - 1.0
libcrashreport - 1.0.2-1
libpackageinfo - 1.0.0-1
libstatusbar - 1:0.9.8.1.1
libsymbolicate - 1.8.0-1
LightningBattery - 1.0
LZMA Utils - 4.32.7-4
Mac Battery - 2.01
NCSingleTapClear - 1.1
Neon Mist- All iOS 8 Devices - 1.0.2
network-cmds - 307.0.1-6
NevaGonnaBuy - 0.0.1-7
New Curses - 5.7-13
NoAdStoreOpen - 0.0.2-1
NoNoNotifications7 - 0.0.1-1
NoPhotosCollections - 1.0.0-1
NoRecentlyDeleted - 0.0.1-17
NoTracking+ - 1.1.2-1
OpenSSH - 6.7p1-12
OpenSSL - 0.9.8zc-11
PAM (Apple) - 32.1-3
PAM Modules - 36.1-4
pcre - 8.30-5p
pincrush - 0.9.2-1
PkgBackup - 8.0.4
Power Tap - 1.1.1-24
PowerSoundDisabler - 1.1.1-6
PrefDelete - 1.3.0
PreferenceLoader - 2.2.2
Profile Directory - 0-2
PullToRespring - 0.0.2-1
readline - 6.0-7
RecentFacebook - 1.0.2-2
ResetAllKiller - 1.0.0-3
RocketBootstrap - 1.0.2
Roomy - 1.1
SaveGram - 1.2-1
sed - 4.1.5-7
SendDelay - 1.0-2
shell-cmds - 118-6
ShowCase - 1.3.5-1
Simply ios8 - 1.0
Simply ios8 i6 Wallpapers - 1.0
Slide2Kill8 Lite - 0.0.3-2
Springtomize 3 (iOS 7 & 8) - 1.3.0-4
StatusForecast - 1.3.0
StickyBanners - 0.0.1-5
Substrate Safe Mode - 0.9.5000
Sudo - 1.6.9p12-4p
system-cmds - 433.4-12
SystemWidePredictiveText - 0.0.1-11
TaiG 8.0-8.1.X Untether - 1.1
TaiG AFC2 - 0.1
Tape Archive - 1.19-8
TechSupport Framework - 1.2.0-1
Touchit iOS 8 - 1.2
TypeStatus - 1.2.1
UIKit Tools - 1.1.9
unrar - 3.6.8-2p
unzip - 5.52-5p
User Agent Changer - 1.1.2
WiFried (AWDL Disable) - 0.4
WinterBoard - 0.9.3918
Zeppelin - 2.1.0-12
Zeppelin Mega Pack - 1.0-2
Zeppelin Requests 1 {citric} - 1.2
Zeppelin Requests 2 {citric} - 1.2
Zeppelin Requests 3 {citric} - 1.0
zip - 2.32-5p
iphonewarrior
13,847
701
That's a nice big list.
You have Crash Reporter installed, do you have any reports generated from StickyBanners?
Dec 15, 2008
5,386
340
Pensacola, FL
It sucks that the dev hasn't responded. I wouldn't think it is because of a iPhone 6 compatibility issue. If so, then wouldn't it not be working period?
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I'm trying out IntelliScreen X 8, which includes Messages+ I'm liking it. It's a three day free trial, than its $9.99. Anyone else have it?
iphonewarrior
13,847
701
Did you manage to come up with a reason why you had to reinstall the app multiple times in order for it to keep working?
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
No, I didn't. I uninstalled it for now, since Intelliscreen x is doing the job. But my trial will run out and I'll reinstall it. @MoneyMaker79 thinks it might only work on an iPhone 6+, as maybe that's what the dev has. I emailed the dev but they haven't responded.
28,365
5,506
It says it's iOS 8-compatible. Devs usually test their apps and tweaks with multiple devices prior to claiming that, so it's doublful that it's 6 Plus-only. Your list of installations is too long for reasonable troubleshooting of compatibility, so it might be difficult to isolate if it is a compatibility problem. It's sounds like it's just another buggy tweak, though.
I'd try deleting it, doing a hard reset and reinstalling it. Also, delete all of your other notification tweaks prior to testing as they would be the most likely culprits.
Dec 15, 2008
5,386
340
Pensacola, FL
We have a somewhat similar list of stuff, and the tweak has never stopped working for me.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Ok. I did all this. Let's see if it works. Than I'll slowly reinstall the deleted tweaks. Here are the tweaks I deleted. IntelliScreen X 8 is not shown but was also deleted.
28,365
5,506
I think the just crashed just re install it. :)
Reinstall it, huh? That's what I suggested earlier today. You've copied and pasted my suggestions in the past. This post is suspicious of that. Please do not start doing that again. Last time I asked you said you don't even jailbreak.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Before I reinstalled everything, it didn't work at all. Than I reinstalled everything and it's working fine. But, one thing I forgot to mention, only messages failed to show when this problem first arose. Gmail and Mail notifications have never been a problem. The one tweak TypeStatus is only iOS 7 compatible but it works. Could it be the culprit? And, why after everything was removed, did it fail to work at all?
28,365
5,506
You'll have to remove TypeStatus and test to see if it was the culprit. This could just have easily been caused by a corrupt StickyBanners installation, which reinstallation would fix. I wouldn't use any tweaks that don't list iOS 8 compatibility as they can be problematic.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Thanks for your help. I'm going to hold off on this for now. It seems to be corrected. I think that maybe it was a corrupted install. I had reinstalled many times before but never hard reset in between.
