Stock weather app
VOLS34
Jun 25, 2010
1,119
79
Is anybody else having trouble with it updating? I know it's not the greatest app but I usually use the widget to get a quick look at the weather but its not updating.
Sent using iCafe app
5,580
It's updating fine for me. Try a hard reset.
VOLS34
Jun 25, 2010
1,119
79
I did that earlier. It appears its not recognizing certain cities I have stored or if my current location is in one of them.
5,580
So it updates weather for some cities? If so, have you deleted the ones that don't update and then added them again?
Sometimes Yahoo weather stops updating for certain areas. This has happened multiple times in my area. Once, it got stuck at 99°Fahrenheit and sunny for about three days, and another time it was stuck at 53°and dark for about four months. O_o The closest cities that had accurate weather were about fifty miles away. I had to rely on apps that didn't use Yahoo weather while I waited it out.
VOLS34
Jun 25, 2010
1,119
79
Some nearby cities do update yet seem to stop for long periods & says "update failed" But then update later. Some are or were doing nothing. I tried deleting the problem ones that I'm in most & going back & adding again but they aren't recognized. No city in the US is when I type it in.
MrMike6by9
Nov 16, 2008
1,482
121
71
Maryland, USA
Try using the respective zip codes for those locations.
YMMV
VOLS34
Jun 25, 2010
1,119
79
YMMV
yes I tried that. No good. Seems to be a cellular data problem but works fine over WIFI.
5,580
Try resetting your network settings.
EverythingApple
Jul 28, 2010
3,864
225
North Jersey
I don't use it much. I mostly use Weather USA and the weather app in chris' Best Free iPhone Apps thread.
VOLS34
Jun 25, 2010
1,119
79
Didn't help. When on wifi everything is ok but when on LTE or 4G only a select few will update.
5,580
I just found another thread about this. It seems to be a known problem that affects a lot of people on AT&T and iOS 6.x. There is one possible solution posted there, but it didn't help everyone. Worth a shot, though.
