Stop popups
Dec 18, 2008
hey all
is there anyway to stop popups from appearing on the screen of the iPhone?
what i mean is: if a sms comes in to the phone, it popups on the screen even when locked. is there a way to disable that? or is there a way to let it disappear after a few seconds?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
You have to go into setting and set up a pass code lock. Set it for every four hours and you'll probably only have to enter the code once or twice a day. This will stop the entire SMS from appearing when the phone is locked.
Download iBlacklist from Cydia. It allows you to disable this.
Dec 18, 2008
Thanks all, will try it out and let u know the results
