Strange battery phenomenon occurred..
rugved1118
Sep 27, 2013
644
#21
I have also heard if you keep charging your iPhone before 90% is consumed, then your battery life would be dead soon. Is it true ?
Dec 15, 2008
5,386
340
Pensacola, FL
#22
From what I'm reading on here now, the myth stands true until proven guilty. But does anyone really true know?
I usually will try to charge my iPhone when it gets down to 10-20%.
5,580
#23
Nope. That's not true. You can keep it topped off.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
#24
Letting the battery drain down to where the phone shuts itself off is not a problem as the phone does so at a point where the battery is not quite completely exhausted. The phone will protect the battery from a complete discharge. I routinely allow the phone to run the battery down to the point of auto shutdown as a matter of course about once a month. Doing so lets the phone's battery calibration adjust as the battery gradually looses capacity over time and accurately display remaining battery life. Doing this as a routine does not shorten battery life in any way and may even extend it by some amount.
Dec 15, 2008
5,386
340
Pensacola, FL
#25
Let's see if I can get more help. Tonight I went to night class and now 2 hours later it's at 37%. It's been draining fast and even shutting off at weird percentages - 33, 35, 27 etc. I plug it in to charge and it turns on at that same percentage.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
#26
If you have tried all the usual tricks of letting it run down to where the phone shuts off by itself followed by a full, uninterrupted, recharge (once or twice), hard reset, restore from back-up, restore as new etc. and none of that has worked it may be time to pay a visit to Apple if you have Apple Care+ for further diagnosis of your problem. Good luck and let us know how you make out.
Dec 15, 2008
5,386
340
Pensacola, FL
#27
I am definitely not restoring and losing my jailbreak. I will, however, let it shut off by itself and recharge to 100% soon. As for going to Apple, I have never had or needed Apple Care+. Actually now it's going to a less percentage, so it's not dying at a weird number anymore. But once it shuts off ill let it fully charge.
Thanks.
iPutz
Nov 20, 2012
964
186
43
72
US Midwest
#28
Again, good luck and let us know how you make out. I bought my iPhone 5 when it first came out and have had no battery life issues with it, so you should not be having issues at this point. I don't think your jailbreak should figure into the battery issue you are experiencing but I am not jailbroken either and I am no expert.
Dec 15, 2008
5,386
340
Pensacola, FL
#29
Again, good luck and let us know how you make out. I bought my iPhone 5 when it first came out and have had no battery life issues with it, so it you should not be having issues at this point. I don't think your jailbreak should figure into the battery issue your are experiencing but I am no expert either.
I don't believe it's the jailbreak. Sadly, the battery, from my experience having an iPhone, has and will never be perfect.
Dec 15, 2008
5,386
340
Pensacola, FL
#31
You can't restore and rejailbreak?
Welllll...ya see....I could...but I.I don't know. I'll miss my jailbreak for an hour! :(
In any case, I don't think it's the jailbreak. I will see after letting it fully go to 0% and die. Before it would die at 30%, and now it's going much lower so that is a plus.
