Strange behavior on my battery
silvermoon
Jul 17, 2013
1,624
179
Washington
I was running a test to see if there is an issue with the battery properly draining. I noticed that the standby and usage time are the same. I put the phone to sleep for five minutes and the standby and usage time increased five minutes.
Ledsteplin
Oct 29, 2013
4,843
997
65
Florence, AL
I saw someone with that and they fixed it by cleaning the USB charging port. It definitely should not show the same.
silvermoon
Jul 17, 2013
1,624
179
Washington
I restarted my phone and closed all open apps. It's not reporting any battery usage or standby time. Do I need to drain the battery? I'm wondering if I have to charge it again to see if the battery is back to normal.
T
The Doctor11
Guest
That might mean something is running somewhere on your phone. I think a good restore should fix it.
5,578
You need to charge it to 100% and then avoid charging it at any point during the usage cycle if you want to see usage statistics. Do that first. If it continues to report erroneous usage data, let it drain down and power itself off and then repeat step one.
silvermoon
Jul 17, 2013
1,624
179
Washington
It's not reporting any erroneous data. The battery life is a lot better than I expected.
Ledsteplin
Oct 29, 2013
4,843
997
65
Florence, AL
Yeah, that looks good. But it's hard to compare, not knowing what you do on your phone and for how long. If you played videos, streamed music and played Asphalt 8 during that 4.2 hours usage, I'd say it's great. If it's mostly using the eiC app, iMessages and a few emails, I'd say it's about right. One thing your screen shot tells me, is that you don't use your phone as much as I do. But I imagine you're on your computer a good bit. It's all phone with me for now.
silvermoon
Jul 17, 2013
1,624
179
Washington
You're right about my phone usage. I mostly use the computer more than I do my phone. I've streamed a few videos. That is about it.
5,578
Sometimes it just needs to be rebooted or calibrated to start reporting more accurate usage statistics. It sounds like that was the case with yours. It's fairly common.
