Strange charging anomaly
lansbury
Jul 1, 2009
45
If I charge my phone using the plug and USB cord it always charges to 98%, even if left charging overnight. If I charge it from my computer, using the same USB cord, it charges to 100%. A first world problem I know, but I'd just like to know why.
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
That's odd. Have you tried unplugging it at 98% and plugging it back in. I've seen this issue before with the battery not charging to 100%. Odd one for sure.
lansbury
Jul 1, 2009
45
I haven't tried plugging it back in as each time I've noticed it was as I unplugged the phone before leaving the house. Thanks for the suggestion I will try plugging it back in the next time I charge overnight using the plug.
iBanana
Jan 15, 2010
713
United States
Ive seen this sort of on my phone. Its a 5, but its charging and itll get to 98% and kinda hang there. Sometimes it will get to 100 and with it still plugged in after some usage the battery % will go down.
lansbury
Jul 1, 2009
45
Charged over night got to 98%. Unplugged and plugged in went to 100%. Unplugged started to use an app (currency exchange rate checker) and it dropped back to 98%. The battery lasts as expected during the day, so not a problem just strange.
Docd
Oct 16, 2011
651
66
Have you tried running the phone all the way down the charging. Could just be a calibration issue.
Sent from my iPhone using Tapatalk -
Ron7624
Nov 11, 2011
82
14
Yes, I did have the issue and solved it by removing the extension cord between the charger and the wall plug. It seems there was too much resistance caused by the extra bit of wire. I'm not electronically gifted at all but I did read that might help and it did.
Sent using iCafe app
lmluciano
Jul 1, 2010
I have a similar issue. When I charge my phone at home it only gets to 99%. When I charge it at my girlfriends it goes to 100%. After what was posted here I realized, at home I have it plugged into a power strip and at my girlfriends it is plugged in to the wall outlet directly.
RBNetEngr
Jun 17, 2013
170
27
That would not be a valid reason why your phone would not charge to 100%. The charger converts the AC wall outlet power to 5 volts DC to charge the phone. The charger can provide that 5v output for an AC input range of 100-240VAC, and 50-60Hz, so it can be used around the world.
I suspect that it was a phone charge calibration issue, and it resolved itself. Either that, or you allowed the phone to discharge its' battery completely, so it could recalibrate the charge percentage.
-rb
rudeboy
Jan 22, 2009
having the same issue, actually this is a replacement for a different 5s which had the same issue.. trying to run battery down tonight...
