Strange Prob Need Advice
davis5050
Aug 18, 2007
192
Well for some reason my never lock keeps locking and I uninstalled vwallpper and I keep getting flames. Is there anything I can do other than restore to fix this?
Dec 10, 2007
710
blacked out
You can ssh into the directory where the vWallpaper content lived to make sure there is nothing left in there (like the fire.mp4) If you don't see anything hanging out in there, you're probably going to need a restore. My own opinion; steer clear of any Skrew applications.
/private/var/mobile/media/skrew/videos/
davis5050
Aug 18, 2007
192
It was in there. But my phone still falls asleep when set to never. Any ideas?
xcissexc
Aug 9, 2007
501
i uninstalled vwallpaper and was still getting the same issue. then i remembered that we need skrew common for vwallpaper so i uninstalled that and after uninstalling skrew common it fixed that problem and a few other problems too. so try uninstalling skrew common and see if that helps you
davis5050
Aug 18, 2007
192
Will I still be able to use ringtones?
xcissexc
Aug 9, 2007
501
i don't think you would be able to. you can make your own ringtones on your comp tho. wavepad is a good program and the trail version has everything you need to make the ringtones, you don't need to buy anything
