streaming videos
ksmoove78
Nov 2, 2007
14
I just want to know how I go about streaming videos on my iPhone.is there an app on installer so I can do it?also I have 1.1.1 and I want to upgrade to the newest firmware.can anyone help me out.Thanks guys!
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
Streaming video and audio are really easy as long as the file being streamed meets specific criteria: total bit rate, and file type. If you are streaming over EDGE, the bit rate can't exceed 70-80 kbps. Otherwise, the stream will be choppy and stop frequently. Over Wi-Fi, you can have much higher bit rates: I've encoded movies to stream from my iMac at about 140 kbps.
Audio streaming shouldn't be a problem (e.g., podcasts) over EDGE. Again, if the file is compatible with the iPhone (you can check by trying to add it to iTunes and synchronize), it should work.
cpolaris502
Nov 15, 2007
132
Rogers, MN
to update, when you plug in your phone to the computer iTunes will come up. then click on the phone on the left column and click the update button.
ksmoove78
Nov 2, 2007
14
my iPhone is unlocked and jailbroken.i want to know the safe/easiest way to upgrade or is it even worth it?
cpolaris502
Nov 15, 2007
132
Rogers, MN
ok, well you didn't say that in the first post. idk how to do it if you are unlocked then.
termleech
Sep 7, 2007
1,154
McPherson, KS
Look at the pwnage project. They will let you load up a 1.1.4 firmware on your phone that will let you unlock and jailbreak it and create a custom ipsw for your phone. That way if you have to restore again it's already done for you.
Mar 22, 2008
17
What about orb? I've tried it out on my computers and it works great. I don't have an iPhone yet to try it out, but I hear it's supposed to work great. What Orb does, is you install a small program on your computer, register for a free account, and when you visit your homepage and login with your username and password, you can view all your pictures, videos, and music on your computer from any other computer, or mobile phone. Basically, anything with a web browser. I really want to try it on iPhone, but I just have to wait to try it out.
http://www.orb.com/
Eragon
Jan 8, 2008
3,056
50
Frederick, MD
http://www.orb.com/
If you have a PC, orb will work fine. However, files can't be encoded in windows media format; rather, you may have to re-encode them to compatible MP4 audio and/or video files. I considered this option - and have used it with my WM devices; but, my Mac is my preferred platform and opted instead for telekinesis.
Here are a couple of links to help:
http://forums.orb.com/viewtopic.php?t=9199
http://code.google.com/p/telekinesis/
Good luck. :)
phsycology
Dec 29, 2007
2,667
23
Bolton, United Kingdom
Good luck. :)
I just use www.box.net, works perfectly.
