Stuck in sync help please
jailbreaknub
Aug 26, 2011
Hello,
I bricked my iPhone tonight trying to restore it using the original jailbreak ispw which is iPhone1,2_4.2.1_8C148_Restore. But it tried to restore it to mfg settings since I forgot to press shift and load the file. Now I am contuinally receiving the 1015 error and stuck in restore mode. I was on the lastest os and I didn't know anything about the shsh so I don't have any....help please.
I have been working with the dfu and tiny umbrealla but nothing is working ever time i go to restore it I get the 1015 error.
The 1015 error is related to the iPad baseband. Make sure the hosts file is still pointing at Saurik's server, try using a stock 4.2.1, and then press shift+restore. Restore to 4.2.1 two times in a row then use Fix Recovery or RecBoot to kick it out of recovery mode. Then jailbreak and hactivate with limera1n and unlock with ultrasn0w.
jailbreaknub
Aug 26, 2011
can I get a link to where i can get 4.2.1? I'm not to sure where to get it lol as you can tell by the username rofl and thanks for the help.
ultrasn0w unlocks. redsn0w jailbreaks. Do you require an unlock?
jailbreaknub
Aug 26, 2011
i click the fix recovery and it says wait for it to reboot but it never does...im kinda wondering if i can use the other one even though im still on 64bit os any ideas any one? My phone will require an unlock. But it was already unlocked before the mess i put myself in.
You also might want to try kicking it out of recovery mode with iREB.
Do you require an unlock or are you using an official SIM card?
jailbreaknub
Aug 26, 2011
i have an official sim that i can use for now but i have tmobile sim for usage of service but when i run the recovery for tu it instaintly closes doesn't go through anything steps on screen....
jailbreaknub
Aug 26, 2011
i used the ireb and it goes right back to the iTunes logo so does this mean ill need a custom firmware? and also that it is tethered?
No, it won't be tethered because you don't need to restore to 4.3.5. Do you have any of the 4.x SHSHs? Do you have access to a Mac? Is the AT&T SIM active?
The SHSHs are listed here:
jailbreaknub
Aug 26, 2011
no but I did go through a video on youtube and so far that has work but it looks like i may be tethered. thanks for the help i got it back up but im trying to get it untethered atm. using green poison
