successful unlock and mods - AT&T customer!
bizzy045
Jun 27, 2007
93
i was able to successfuly unlock and mod my iPhone using anySIM, AppTap, and iBrickr. The whole thing was very easy, and I ran into no problems. I tested it with a prepaid tmobile sim card, and everything works like a charm.
no more international roaming! those rates were a joke. Now I can just pop in a local prepaid sim, and will save a lot of $$$. i travel out of the country a lot, thats why i decided to unlock the phone...
Lets hope the firmware update doesn't relock the phone.
Stevonw
Sep 14, 2007
560
UK
i was able to successfuly unlock and mod my iPhone using anySIM, AppTap, and iBrickr. The whole thing was very easy, and I ran into no problems. I test with a prepaid tmobile card, and everything works like a charm.
FINALLY, SOMEONE WHO CONFIRMS WHAT I'VE BEEN SAYING IN ANOTHER THREAD ALL ALONG. :laugh2::laugh2::laugh2:
The free unlock is as easy as the paid for. To achieve the paid for, you must use almost the same steps anyway! Thanks for confirming the Windows installation is as easy as the OS X installation mate (i used the OS X install which was very easy also)
garymooks
Jul 18, 2007
31
I did the unlock of my ATT iPhone with unlock(previous version of anySIm),AppTapp and Cyberduck.
Tested with T-mobile pre-paid..no problems so far..
To all:
Was this the first try for y'all?
How do I restore back to locked-with-att-warranty-intact state?
vtec236
Sep 11, 2007
22
Colorado
i unlocked my phone but when i tried a buddy's tmobile sim it loses icons so when i restart it says that i need to reactivate with iTunes?
thesheikh
Sep 16, 2007
i need help
i try to use anySIM but when i do it says cannot patch files.
how do i fix that
bizzy045
Jun 27, 2007
93
you have to do a virgin restore:
http://www.iPhonegoboom.com/#restore
once you do that, you have to go through the entire unlock process again.
this is what i did:
http://www.hackint0sh.org/forum/showthread.php?t=7007&page=7
you are getting that error, because you tried to unlock more than once.
when I did it, i got an error saying something like "Flash successful, but unlock failed. Please check minicom for error"...it was something like that...that is normal as anySIM has a bug where it does not report the right msg. your phone will be unlocked. do not try to run anySIM again. otherwise you will have to virgin restore and redo the unlock process...
HELPmepLox
Jul 15, 2007
So.Cal
when u unlock your phone doens;t it require u to open the thing up and sawder something inside?
bizzy045
Jun 27, 2007
93
nope...just install a pxl package using iBrickr, and run the app on your phone...no hardware mods at all...just software..
