Summer board question
Domin8stang
Jun 25, 2007
90
Is it possible to have all of my icons on the dock so I can see my wallpaper perfectly at all times like this. http://www.hotlinkfiles.com/thumbs/small/817409_3ihdg/EXAMPLE_054753.jpg
open customize and set the springboard icons to zero. then download and install the program called "dock" and it will put a small sunburst in the bottom right of your screen, and you touch there and it brings all your icons out and you can go through by sliding your finger and pick which one you want...or search Modmyifone for the transparent icon set, thats what i use.
