Summerboard 1.1.1
sr4482
Oct 9, 2007
27
I followed the instructions on the summerboard site, but it still doesn't work properly. It shows the icon on the screen; however, it freezes for a couple seconds then reverts back to the springboard.
ANy suggestions?
wildonrio
Jul 4, 2007
2,002
Provo, UT
ANy suggestions?
Did you change its permissions to 0755 in WinSCP or the like?
Aug 9, 2007
178
Can someone do a "Dummy's guide" for this
I read the manual install instructions, but I was unsure where to copy most of the files. Most of the folders it specified did not exist and I was unsure where or if to just create them. :sick:
enigmanic
Jun 27, 2007
513
For SummerBoard.framework and SMBPrefs.app, just drag those folders to their respective locations. For Themes, yes...you'll have to create a new directory in
/var/root/Library/ called SummerBoard, then a subdirectory called Themes.
Remember to set all plists permissions to 0755.
sr4482
Oct 9, 2007
27
When you drag Summerboard.framwork and SMBPrefs.app are you replacing the folders already there or just placing them into the folders that are there (there are already summerboard.framework and smbprefs.app folders).
enigmanic
Jun 27, 2007
513
Summerboard.framework and SMSPrefs.app should not be there yet, unless you are attempting another manual install. If so, just replace over the old Summerboard.framework and SMSPrefs.app folders.
sr4482
Oct 9, 2007
27
Ok...I did everything it said to do and still can't get it to come up. The icon is on my spring board and when I click on summerboard, it tries to come up then crashes back to the spring board. Anyone suggestions?
Aug 9, 2007
178
permissions
how do you set plist permissions ?
enigmanic
Jun 27, 2007
513
Try starting up Summerboard a few times. It crashed on me about 3 times before it finally opened up. Now it seems to work flawlessly.
sr4482
Oct 9, 2007
27
Do you set permissions just on that one file?
enigmanic
Jun 27, 2007
513
You must set all Summerboard plist files to 0755. There's a plist file in SMBPrefs.app, SummerBoard.framework, and of course com.apple.SpringBoard.plist.
sr4482
Oct 9, 2007
27
OK...really not sure what's wrong with Summerboard.
I redid it over 4 times and it still won't come up. It keeps trying to activate...then crashes. I did it exactly like the directions said to do and i did change it to 0755.
Anyone else continually havnig this issue?
sr4482
Oct 9, 2007
27
Upload...seems like several of us are having the same problems.
enigmanic
Jun 27, 2007
513
The only other thing I can suggest is to set 0755 permission to ALL files within SMBPrefs.app and Summerboard.framework. After setting these permissions, restart the iPhone.
To amalone87: com.apple.SpringBoard.plist goes into:
/System/Library/LaunchDaemons/com.apple.SpringBoard.plist
Also, please note: this Alpha Summerboard is for 1.1.1 jailbroken phones/ipod touches only.
sr4482
Oct 9, 2007
27
Enigmanic
Enigmanic,
Under system/library/launchdaemons i see a com.apple.springboard.plist file. Do I replace that file or just add another folder with the new com.apple.springboard.plist file?
enigmanic
Jun 27, 2007
513
Enigmanic,
You replace the existing file. And remember set octal permissions to 0755.
Did you get my private message I sent you? Let me know if you need any help....
I made the 0755 change to all files in the SMBPreff.app folder and now my SMBPreff app works!
Thanks enigmanic! :laugh2:
