Summerboard 2.0 and DockSwap
krisobe
Jul 20, 2007
233
i just installed the latest summerboard which is really cool, but when i opened up dockswap and changed my dock it doesn't work. any one have this same problem?
jerrettpaul
110
Denton, TX
yeah im having the exact same problem. i don't know why it's doing this though.
Domin8stang
Jun 25, 2007
90
ha, i saw this thread...checked updates and installed..then went "DOH!"
krisobe
Jul 20, 2007
233
i just installed summerboard 2.0 and went back to 1.91 and dockswap works again. i hope they fix this problem in 2.0
antithetic
Jul 9, 2007
69
The new version of SummerBoard appears to have it's own dock image management since it now supports Themes.
There are also new dock options (None/Mini/Large) and Wallpaper settings (None/Settings/Theme).
krisobe
Jul 20, 2007
233
uninstall from ibrickr, then go to applications and find summerboard and it should be 1.91. i don't think they updated to 2.0 on ibrickr yet. so yeah just click on 1.91
Domin8stang
Jun 25, 2007
90
i got an idea....what if you go into the file folder of the dock program and pull the image you want and drop it in the themes things for summerboard? imma go try and figure this out.
venturo
Sep 9, 2007
30
way to save me guys haha, i think ill wait on the summboard, i like my current dock settings :-p
krisobe
Jul 20, 2007
233
i was just thinking about this. cool man please tell me if it works!
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
Looks like I'm assed out I use installer/apptapp...
krisobe
Jul 20, 2007
233
try using ibrickr as well man!
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
I'm on the road I'm more mad because I hade a nice set up with my own dock and I was egger to show people but with my dock disabled it looks like crap.... Hope summerboard or dock swap fix it !
Thaanks
Domin8stang
Jun 25, 2007
90
this can be done with mobile finder :cool:
ok just navigate to
Library/Dockswap/Touch/ and select touch.png and hit > Copy
then navigate to
Library/summerboard/themes/default/
then hit "info" in the bottom right of the finder app, and change the file name to dock.png
restart your iPhone and select "default" theme, and then for the wallpaper use "settings" and it works :cool:
Domin8stang
Jun 25, 2007
90
damn im glad that worked, it was the first time i'd used the finder app/ moved anything around inside the phone...genius! hahaha
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
you are theeeee man. I swaped out the files and made my own theme... I turned the summerboard theme into my own ... I repleced the dock and the wall paper and now its my theme.. Good call man ... The best thing is that i did this on the road via mobile finder .... Thanks bro!
Tip.
Once you change the files keep the names as they were before
Good luck
neph19d
Jul 5, 2007
55
whats dockswap
