summerboard 2.1 already out on installer.app
Ace4261991
Jun 18, 2007
530
things ive noticed so far.. new icon for SBM preferences and then a new theme and some new options im not sure which ones are new because i didn't pay attention to the ones that were there fore 2.0
the new themes pretty sweet it adds ipod touch-like icons its called louie mantia
i wish we could have an app that we can arrange each individual icon/dock/wallpaper to our own likings to make a completely custom theme
jerrettpaul
110
Denton, TX
i agree. i really really like the new summerboard though. MUCH more than summerboard 2.0!
x999x
Aug 6, 2007
1,656
You can, just move the theme files around using MobileFinder.
The Themes are located in this folder:
var/root/Library/SummerBoard/Themes
To create your own theme, create a new folder and place the following images in the folder:
MiniDock.png*
StatusBar.png*
*optional
To replace the icons for your theme, place an Icons folder in your theme folder and place the following files:
var/root/Library/SummerBoard/Themes/ThemeName/Icons
Ace4261991
Jun 18, 2007
530
i know you can do that but i was talkin bout like an actually appl;ication that showed an example iPhone with your current icons and theme and you can just easily swap any out then save it but thanks for tryin to help
jerrettpaul
110
Denton, TX
the icons are not working for me : / im doing exactley what this says. what might be wrong?
x999x
Aug 6, 2007
1,656
You need to restart your iPhone to see the icon changes. To do this quickly just goto Summerboard prefs and click Restart Summerboard.
Jasper44
Sep 3, 2007
No they show up without restarting. The problem I had, which I think a lot of people might have, is that the new icon changing system changes them based on what the icon text is. For instance it puts the text.png icon in the place of the icon that says text under it. So if you have edited your LocalizedApplicationNames.strings to make them all blank then the icons wont change. Re-upload one with all the text under the icons then turn the text off with the new option in the summerboard preferences,
