summerboard for 1.1.2
ClutchNY
Nov 4, 2007
21
www.myspace.com
how do i get summerboard and installer for a locked (AT&T) that was bought with 1.1.1 and upgraded to 1.1.2?
Chris716
Nov 29, 2007
807
IL
you will need to downgrade to 1.1.1 then jailbreak the phone go to jailbreakme.com from the iPhone once you have downgraded youwill have to do this on wifi being that the phone most likely wont work. Once you do this and have installer downloaded go and download ok2prep then you need to upgrade the phone back to 1.1.2 then download the jailbreak software from conceitedsoftware to jailbreak then you are all done and will have installer then you can download summerboard
