Summerboard for 1.1.4?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
There's a version showing up in Installer right now that says 1.1.4.
I haven't tried it yet as I figure I'll stick on 1.1.4 for a few days ...
tundra
Jul 15, 2007
57
New Jersey
Poof has been updated to work with 1.1.4 as well... also see there is a 1.1.4 compatibility patch to allow 1.1.3 apps to run on the 1.1.4 firmware. i think I will now take the 1.1.4 plunge. I know there is nothing exciting added but I have been having a lot of problems with signal drops. Just hope it helps.
Crazieukfan
Jun 25, 2007
41
i don't see the summerboard update or the patch where are these
jUeLz23
Sep 4, 2007
350
me either........ don't see it there
tundra
Jul 15, 2007
57
New Jersey
I Believe the patches are part of spazio source. I do not have time to refresh sources ATM but install Shai's source then install his sources collection. It should show up then under recent packages. Hope this helps you guys out. Good luck.
jUeLz23
Sep 4, 2007
350
and where can we find the link.. tried to google the name and nothing came up
edit::: found the link
jUeLz23
Sep 4, 2007
350
I installed the sources. All sources still doesn't show a new summerboard
jUeLz23
Sep 4, 2007
350
^did all that all sources are installed and I still don't see it
jUeLz23
Sep 4, 2007
350
finally got it to work......
altought customize doesn't save the settings well atleast not for me
Feb 28, 2008
forgive my ignorance, but I did all of that too and don't see it either(added the source and then the Shai source app added the 94+ sources but nothing has really changed in the apps available). Can you tell me what you did for it to show up?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
I think it's this source that'll get it to show up:
http://planet-iphones.com/repository
x999x
Aug 6, 2007
1,656
I'd advise 1.1.4 users to take note that the above repository is just hosting the same SummerBoard for 1.1.3, however they've just removed the firmware check from the preflight sequence of the Installer in this case.
Additionally the package which is installed is not hosted by Null River, if that makes any difference to you or not. Here are the keys which show that this shouldn't be perceived as the official 1.1.4 release, but instead a very clever work around for early 1.1.4 adopters:
<string>SummerBoard (No Themes)</string>
<key>version</key>
<string>3.1-1</string>
<key>location</key>
<string>http://planet-iphones.com/repository/zips/summerboard_no_themes.zip</string>
<key>description</key>
<string>SummerBoard for 1.1.4 that installs with no additional themes. Made by NullRiver Software.</string>
<key>category</key>
<string>PI (1.1.4)</string
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
I can't get Summerboard to work. Any help?
I went with a fresh 1.1.4. Then I jailbroke it. Then installed bsd subsystem. Then installed the 94 resources and refreshed. Then i went to recent apps and installed the 1.1.4 summerboard fix. Then installed summerboard and then uninstalled the fix (per instructions that came with the fix). Reboot phone and all works well.....
bkushner
Jan 22, 2008
69
I did the same and summerboard is working, however, some of the themes I install ie; Louie Mantia Aqua does not show up in SMB after install?
Brian
jjsquizz
Nov 10, 2007
252
Los Angeles
Oj, where did u find the 1.1.4 summerboard fix. And is there one for Customize also? Thanks in advance
