SummerBoard On 1.1.3, Anyone Have It Working?
RTWilliams2
Oct 3, 2007
66
Someone said they had Customize working on 1.1.3 and I was just curious if anyone has SummberBoard working.
madhurdutta
Jan 1, 2008
I do, just install it from the internet(google summerboard download) and than ssh it to applications
works fine except for a few things.... like dock does not work, does not skip last line, but does change icons.......
Goodlife08
Jan 23, 2008
53
Google it on the iPhone ? and what is ssh?
Goodlife08
Jan 23, 2008
53
well ive already jailbroke to 1.1.3 and have downloaded the SSH package and BSD thing but don't know what they are...could you briefly explain please
Griffinaz
Oct 5, 2007
1,048
Phoenix, Arizona
SSH is a means to access the files on your phone from your desktop computer. There are several different programs that allow you to do that. Using SSH you can copy programs directly onto the phone, place them in the correct position on the file structure and then set the correct permissions so you can run them on the phone. Installer is a simplified means to do this and for those not familiar with SSH and the dangers that are involved if you are careless, Installer is the way to go.
The BSD Subsystem is a behind the scenes software package that allows certain programs to communicate with the operating sytem and there are programs on installer that require that be installed in order to run.
Goodlife08
Jan 23, 2008
53
okay thanks for the info, think im gonna stick with installer since im still a nwebie at this
So is there any way to get Customize and/or Summerboard for 1.1.3 via installer?
15,385
1,023
if they're not in there, just wait for it. i'm sure they're working on updated versions for 1.1.3. the jailbreak WAS just released yesterday... give them a few days.
RTWilliams2
Oct 3, 2007
66
I did that but it didn't work. It would open up a blank screen.
madhurdutta
Jan 1, 2008
http://www.all-Apple.com/2007/11/26/summerboard-download.html
Here is where I downloaded my summerboard from.
SSHed following files in the following directory
SummerBoard.framework -> /Library/Frameworks/SummerBoard.framework
SMBPrefs.app -> /Applications/SMBPrefs.app
Themes -> /var/root/Library/SummerBoard/Themes
com.apple.SpringBoard.plist -> /System/Library/LaunchDaemons/
Hope this works!
Regards,
Madhur
!UPDATE!
Get the dock to work by replacing the following files with dock images of your choice.
SBDockBG
SBDockBG2
/System/Library/CoreServices/Springboard.app
Than your dock should work too!
P.S - Back up all files, if you ever want to revert to the original.
Madhur
In
madhurdutta
Jan 1, 2008
I hope they get this thing fixed properly soon.
I'll be watching this thread.
What do you mean by that?
Anyhow my procedure to get Summerboard working has been rechecked and it works using the methods posted in my prior post!
Cheers.
Madhur
seb481
Aug 3, 2007
774
San Diego
Hope this works!
Regards,
Madhur
!UPDATE!
SBDockBG
SBDockBG2
Madhur
In
Could you please detail the process by describing each step more deeply? Thanks
madhurdutta
Jan 1, 2008
@ SEB481
Download summerboard from the link specified in my prior post. ON YOUR COMPUTER.
Learn how to use SSH on 1.1.3, if you do not know already here is how i think its done.
Re-Instal BSD Subsystem, if not installed, find it in installer and install it.
Than install Open SSH.
Than buy a app called transmit, or a other Free equivalent.
Create a new SFTP Connection,
Put in your server(iPhone Wifi settings)
your username is root, password is alpine.
Hit connect.
NOW....
Copy paste the following files through SFTP(Transmit or SSH) in the respected directories on your iPhone.
These files are there in the above mentioned download.
To get the dock working ask me for a dock you want and I will make a copy, for you to paste in the following directory
If you do already have a dock image (probably named Dock.png) on your COMPUTER, THAN using Transmit AKA SSH, make two copies of the Dock.png
Rename one SBDockBG
the other SBDockBG2
and paste them into
I am going to sleep,
Any one who knows how to use SSH should not have any problems, cause in my opinion i have made this post taking Newbs in consideration(As i am one of em)
Here is my Screenshot
http://i142.photobucket.com/albums/r87/madhurdutta/IMG_0342.jpg
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Cheers.
Madhur
No your method is fine, I was talking about the developers patch being fixed.
Now I see your tut so I will try that, thanks.
seb481
Aug 3, 2007
774
San Diego
@ SEB481
Hit connect.
NOW....
Rename one SBDockBG
the other SBDockBG2
and paste them into
Thanks man, it does help a lot!
