Summerboard on 1.1.3?
Jul 14, 2007
19
i recently downloaded summerboard on 1.1.3
it works, but when i download wallpapers for it, it doesn't show up on my main screen background..
does anyone else have the same problem?/
Popdevil
Jul 2, 2007
254
Yeah, the themes in the app work but if I download any new themes they will not show up on the list to select from.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Try running the Smb Themes Fix, from Big Boss source, which seems to provide all the best instant fixes for 1.1.3 JB issues.
You need to add the Big Boss Beta/Experimental source - once you do, you should see the Smb Themes Fix under the Tweaks (1.1.3) category ...
Popdevil
Jul 2, 2007
254
That worked for me.
mflantin
Nov 29, 2007
100
Is it me or did they delete the feature that allows you to skip the 4th row in the new Summerboard?
hinzy
Feb 6, 2008
72
Why would you need it if you can move icons on 1.1.3? Just don't put any on the bottom row...
mflantin
Nov 29, 2007
100
That's great! I didn't know you could leave blank spots when re-arranging with 1.1.3. Thanks...
