summerboard problem on firmware 1.1.1
haseeb
Dec 16, 2007
summerboard problem on firmware 1.1.1 hey dude my name is haseeb i have a problem with my iPhone fm 1.1.1 its unlocked nd jailbreaked
ok the problem i tried installing summerboard VIA Ibrickr nd while it ws the installer the processing circular animation appeared which appears all the time wheneva u install an app so thn it ws moviing nd thn suddenly it started blinking nd my iPhone got stuck thn i had to reset it by holding the home nd the switch off button it ws a pxl file obviously
so please help me wht am i doiing wrong
any ideas
thx
Chris716
Nov 29, 2007
807
IL
just upgrade to 1.1.2 and jailbreak it then you wont have the issues...
Spoolin414
Dec 6, 2007
93
Ft Lauderdale, FL
Use WINSCP and check to make sure there is not a previous directory for the APP your trying to install if so delete it and refresh. Should fix your issue
haseeb
Dec 16, 2007
thx but i still need help
dude yeh please im trying to contact u via AOL
my nick is haseebh2
so please i need your help im a complete noob thx a lot
haseeb
Dec 16, 2007
please can u tell me step by step please i don't have wifi in my house so im using iPhonebrowser so please step by step thnx
termleech
Sep 7, 2007
1,154
McPherson, KS
The circular thing when you install an app from installer is normal. It's just resetting summerboard to include the new app. Was this your question?
haseeb
Dec 16, 2007
no like thn after tht the circular thing stops moving and thn it keeps blinking nd thn my iPhone gets stuck
so tht ws my question
