Summerboard questions and misc ziPhone questions!
May 19, 2008
I downloaded summerboard, reset the phone, and downloaded a theme. I set the theme but it doesn't work, the default theme is still there. help?!?! thanks!
btw anything come out yet to send pics to other cell phones instead of email? thanks!
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
Have you made sure that the theme is selected and then looked to see if the individual components of the theme are activated? You should see options like:
Theme Wallpaper ON/OFF
Theme Status Bar ON/OFF
Make sure that you turn those to ON otherwise you wouldn't see a difference.
