Summerboard scrolling?
itcomic
Oct 15, 2007
14
Currently I have 1.0.2 iPhone and installed summerboard with the latest version of app.installer
I have installed app.installer, PDFviewer, sketch , mobileRSS and summerboard.
When I try to use the "scroll" function it doesn't work. Is there any setting I need to turn on to use the scroll the main screen function ? (i have tried turn on all functions available from summerboard and still no luck) please give me some advise.
Thanks a lot
akophone
Aug 1, 2007
300
Sometimes turning the phone off and on again does the trick. If not, uninstall Summerboard and reinstall it (Summerboard old version). Turn the phone off and when you turn it back on, you should be live! Good luck!
iFuNk
Oct 25, 2007
93
I thought that scrolling was native to the iPhone's firmware ?
paulomb
Oct 1, 2007
72
Monterrey, MX
do you strongly recommend to install Summerboard (old version), instead of the new on a 1.0.2 phone? since installer has both options available...
jc2o1
Dec 1, 2007
I installed the newest version of appsnapp and summerboard, but the screen doesn't scroll, it makes pages. Any ideas?
