Summerboard = Springboard on roids
x999x
Aug 6, 2007
1,656
Check your Installer.app and get to installin' Summerboard!
Easy scrolling of your icons, and an actual skinnable background. It displays your Wallpaper as your current background, so you may need to select something more appropriate, i.e. something that doesn't make your icons hard to find.
RTpics
Jul 19, 2007
80
Malibu CA
ooo that is kool better than the other version "dock" that needs 6.6mb of bds sub system to be intallled.
x999x
Aug 6, 2007
1,656
This really makes skinning A WHOLE LOT EASIER!
I never bothered because of the whole process involved with faking a background image.
gcvt
Jun 21, 2007
1,029
San Francisco
Pretty sweet. I like it much better than having to go into launcher or use Dock. :cool:
The scrolling isn't quite as smooth but I assume that can be fixed later. Also, it didn't stop scrolling at the bottom of the screen but just kept scrolling to blackness. Then a reboot fixed that issue.
H
Hayesimus
Guest
D'oh! I just left a post about this in the mods section! lol. I concur! this is like the best thing that's happened so far. Combine this with RSBT so you can move around your icons and get things like stocks and whatever else down to the bottom and you're all set! I could think of some improvements but who couldn't. That being said, I'm just about as thoroughly satisfied with my iPhone now as I can be! Now i just wish there was an app that could change my carrier logo and the like. Everything i've seen so far is rather complicated. and i'm not that technically inclined.
alb0zf1n3st
Jul 2, 2007
624
As much as I like the fact it scrolls the icons .. I Mean yeah its insane and I like it a lot.. I just don't like the fact it uses the wallpaper I have on the locked screen lol.. yes granted I can get a black wallpaper to make it like the original but then my lock screen is black too...
I just looks to messy on the home screen with wallpaper showing .
gcvt
Jun 21, 2007
1,029
San Francisco
Yes, that is clearly a big problem. Since this is the original release, there's a good chance that will be changed soon. At least I hope so.
H
Hayesimus
Guest
oh i LOVE that it has the background image. however i do see your point. i would like two different images for those screens as well. perhaps an update that will let you pic which screen is gonna be the background and not just snatching your wallpaper settings? sounds good, right? :laugh2:
nobbie
Jul 23, 2007
282
I'm sure that'll get worked in.
kwan
Jul 7, 2007
88
Changing the carrier logo is very easy. Are you on windows or mac?
on windows use ibrickr. Then all you have to do is change 2 files
let me know if you need help
j2chulo
Aug 25, 2007
27
Wow nice. I being waiting for sumething like this. i was going crazy loosing my icon and them launch wasn't on the first screen either. i was looking into iFuntastic just because it let you create multiple home screen and that was my only choice to get all my app visible. i finally got the Dock installed but Dock has a big problem i will make a post explaining it. Any way i love this im getting rid of Dock and Launch
H
Hayesimus
Guest
yep, that's what i did. i feel bad though because i really liked what the "dock" guy was working toward. just... this was better? sorry guy if you read this.
Tinman
4,334
183
Aridzona
I like Summerboard and Dock. They compliment each other nicely. Dock has had some major updates, just yesterday (much bigger icons, easier to select, etc.).
Summerboard is great in concert with rSBT. I moved the apps I wanted to see to the "Third Party" section. After I moved one app there nothing in "Hidden" showed up in Summerboard. So I moved most other apps up to Third Party (but not every one--such as Preview and TextEdit which are better used with Mobile Finder).
One thing I think the iPhone needs is a way to control multi-tasking, and the saving of states.
MIke
H
Hayesimus
Guest
i wish that the peeps that made the tictactoe would make it to where you can choose 1 or 2 players. kinda would make it more fun if you and a friend could be sittin there on break or something and play tictactoe lol
wildonrio
Jul 4, 2007
2,002
Provo, UT
I love this, but the only thing I don't like is now all my lazy icon-makers are made known, such as SendSong and TicTacToe. I can see an ugly black square around them now. I'm sure they thought no one would notice against the black background but now with a wallpaper background it is noticeable and hideous.
stewcp
Jul 24, 2007
105
Bristol, UK
Great program! but one small bug... the red text notification with count doesn't appear next to the springboard icon anymore! Also, I don't appear to be able to uninstall it!
wildonrio
Jul 4, 2007
2,002
Provo, UT
I can uninstall it alright, but the text count thing is really annoying. I hope they notice this and fix it...
H
Hayesimus
Guest
i just had this happen, but i don't think it was because of this program. i think it was another program that was causing the glitch. either way. i turned the iPhone off and back on and it was gone. plus i deleted things like Launcher and Dock being that they are useless now that this app is available.
mattolson
Aug 23, 2007
hmm
When I installed this is also installed demoapp and fieldtest and now I have no idea how to get these two things off my phone because I have been using ibrickr and Installer.app and either of these notice these apps are installed, any help would be greatly appreciated.
H
Hayesimus
Guest
those are programs indigenous to the iPhone. probably something Apple will be unlocking with an update at a later date. at least that's what i've been told
