summerboard themes won't work
Teejo
Oct 24, 2007
I'm on 1.1.1 and virtually every theme I load through installer will not work. Out of 20 + that I have tried only 2 have worked. Am i missing something? Any advice would be great
Terry
x999x
Aug 6, 2007
1,656
Terry
You may have a small issue, try restarting before you download.
Teejo
Oct 24, 2007
I gave that a try. Still won't work. I'm running summerboard 3.0a9. Anybody else have any ideas? I don't want to use customize until i hear better feedback about how it runs on 1.1.1. Its weird because I can can get 2 themes to run (loren and litho) but ive tried at least 10 others with no luck
T-
Stevonw
Sep 14, 2007
560
UK
T-
Most themes (except the standard ones that come with the newer summerboard don't work!) this is because Apple have changed a lot of the file names etc.
Teejo
Oct 24, 2007
bummer
Thats a bummer. What other options are there? is customize running without issue on 1.1.1 yet?
T
