Summerboard
skinnydmag
Sep 12, 2007
i hav version 1.1.1 installed on my phone and im wit att but is there a legal way to install summerboard on my phone
stewcp
Jul 24, 2007
105
Bristol, UK
Short answer... NO! Apple dosn't allow any third party apps.
... and this post doesn't have much to do with wallpapers ;)
shelly_m
Apr 2, 2008
I downloaded the SummerBoard Theme into my iPhone. However, I am not able to run the same. Let me know whether I need to install a software to run the theme in my iPhone, if yes then which software?
Thks
Bone
Feb 11, 2008
1,214
u need to install summerboard first. Then u can change the themes u have installed for it.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Thks
Uninstall the theme first, then install Summerboard and then reinstall your theme. I had installed some themes and forgot to install Summerboard first and my themes didn't show up, so I had to do it that way.
gemroz
Jan 5, 2008
25
I tried to install the old and new version with my installer and and it says "package download failed" can anyone tell me why or how to fix it? Im trying to install it so i can get video wallpaper. thanks everyone
chcorey52
Dec 25, 2007
556
ummm refresh community sources? im pretty sure
chcorey52
Dec 25, 2007
556
Whenever this happens to me i try a few things....sorry again if this doesn't help.. i clear my qeue,refresh turn off phone, turn on airplane mode, and see if other things are installing...good luck
unkmark
Apr 3, 2008
37
turn the wi-fi off...this is a common problem, that i have had.
and make sure you clear the queue
now if this happens to every program you try to download it may be a more complicated problem.
24trepid
Jan 13, 2008
502
I always just refresh sources, and my apps download correctly.
