Sunlight viewable?
JASmine
Jun 22, 2007
For those who have iPhones, how is the display in bright sun?
prolix21
Jun 29, 2007
90
it was pretty good. i was out playing mini golf sunday and i had no issues. i think the backlight/brightness auto-adjusts
thinkart
Jun 16, 2007
212
Mid-MO
i think it works great outside (UNLIKE BB's)
JnC
Jun 17, 2007
333
It seems to work decently well in the sunlight. Enough to make out names. Some things are a bit washed out, but it's certainly functional. It helps that most lists are dark characters on a white background.
It doesn't have an auto adjusting light sensor. Apple thought the iPhone changing brightness often would be distracting. If you walk outdoors while using it, put it to sleep then wake it up. The light sensor only takes readings/adjustments when it wakes up.
bkid97
Jun 27, 2007
11
well you can adjust the brightness and when you put it up all the way its perfect in the sun for real very cool
