super mario sound fx?
iNoob
Sep 2, 2007
24
I finally figured out how to add ringtones and change the message tones and such. Can someone please tell me where i can find videogame soundfx? I specifically want the super mario power-up and power-down sounds for unlocking and locking my iPhone.
I tried vgmusic.com but the sounds werent on there.
thanks!
abnormal
Sep 13, 2007
I am interested in this as well. Someone here mentioned having the New Super Mario Brothers BuhBye sound (when you close the DS) as their lock sound, and I thought that was an awesome idea, but have had no luck searching for it.
abnormal
Sep 13, 2007
OK, I have captured the sounds from my DS, but the AIFC files created from WireTap aren't compatible wit the iPhone... What should these be saved as? I see others in Customize are using aif, but just renaming won't work, so I need to convert. MP3 files available for anybody that wants the sounds by the way, and i hope to have them up on installer.app once they're working
wildonrio
Jul 4, 2007
2,002
Provo, UT
thanks!
This site has them all, but I don't know how to download them
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Yeah if you have any kind of sound editing software on your computer then you can run it while playing the sounds and record and edit them through the software. I have Soundforge for this very reason.
abnormal
Sep 13, 2007
I already have the sounds ripped (From New Super Mario Brothers, by the Way, not SMB1... I wanted the "BuhBye" and "It's a me, Mario!" samples when I lock/unlock the iPhone).
What I am curious is how do the files need to be structured in order to work as system sounds in the phone. MP3 and AIFC files won't work... And do they need to be 44.1khz 16bit stereo like CDs, 48k like DVD, ... or what?
Bry
wildonrio
Jul 4, 2007
2,002
Provo, UT
Bry
I'm pretty sure they just need to be wave format, but with the extension changed to .cab. Try it.
ataq
Sep 17, 2007
33
i can atest that wav files work as i just added these sounds to my brothers iPhone's UI sounds
entong
Sep 21, 2007
154
yeap it works just fine. i have em on my phone :)
