Swap tunes from iBrickr
wildturkey
Aug 14, 2007
168
can someone tell me how swap tunes works its not doing anything when i hit the button it doesn't switch to anything just a black screen with the swap tunes in the middle.....Thanks
krisobe
Jul 20, 2007
233
1st download installer via ibrickr. then open up installer via iPhone. wait for it to update. install community sources. then install bsd subsystems. then install swaptunes and voila! swaptunes now works. i had the same problem when i installed swaptunes via ibrickr then i researched around forums and found the solution. i love installer!
krisobe
Jul 20, 2007
233
hope this helps man. swaptunes is the coolest thing ever invented since i just reformatted my computer and im too lazy to set up my playlist again.
wildturkey
Aug 14, 2007
168
thanks i'm new to this how do i get my own wallpapers using install
krisobe
Jul 20, 2007
233
what wallpapers are you trying to get? you can just upload pictures to your iPhone via iTunes then just set them as wallpaper. have you installed summerboard yet? you can have your wallpaper on the home screen as well as making your home icons scroll up or down. really neat.
wildturkey
Aug 14, 2007
168
can you change icons from the installer?
krisobe
Jul 20, 2007
233
no i don't think so. u can change icons via ibrickr
