SwapTunes help!
krisobe
Jul 20, 2007
233
i installed swaptunes via ibrickr... when i click on swaptunes on my iPhone, it doesn't seem to work. the app just closes again after 10 seconds. it shows the icon and says its swapping, but the other folders are never made, so it never swaps. anyone got swaptunes to work?
kwan
Jul 7, 2007
88
Yes, for some reason installing via iBricker didn't work for me. I ended up installing installer v2.3 via iBricker. Then install sbd subsystems via installer using your phone. Then install swap tunes via installer.
I think Swap Tunes needs sbd subsystems in order to work.
krisobe
Jul 20, 2007
233
how do i get "installer"? and how do you install subsystems and how do you install swaptunes via installer? is it easy like ibrickr? thanks kwan ive been waiting a week for someone to find out.
