Switching off Undo Typing Message
jalalawi
Apr 23, 2011
246
My phone fall down and it one of the defects that happened to it that is bothering me is whenever I type anywhere I am always getting the "Undo Typing" message and didn't find anything under the setting to stop this message!!
Any help to solve this?
5,578
Is your phone jailbroken? If it is, install NoAnnoyance in Cydia. It disables the "Undo Typing" popup. I just tested it on 8.1.2 and it worked.
http://repo.pnre.co/tweaks/noannoyance/
5,578
Apple doesn't allow disabling the popup on stock devices. What firmware are you on? If you are on 8.1.2 or lower you can jailbreak. If you can't jailbreak, the only thing I can think of that you can try is restoring in iTunes. I doubt that will fix it, though. It sounds like there is a hardware problem with the accelerometer (making it overly sensitive) and the only way to fix it would be disabling the popup with a jailbreak tweak.
