Symlinks and memory space.
blacklabel775
Jul 5, 2007
62
Well, with the help of 666 I created some symlinks from /var/root/..... to var/mobile/..... to get summerboard and customize themes, NES games, etc. from installer to properly display. But then i thought, why not just directly symlink. So i deleted everything in /var/root/Library and then symlinked /var/root to /var/mobile and rebooted. The "connect to iTunes" screen came up, so i did and it activated. And it worked perfectly.
My question, however, is:
Will this direct linking create two of every file i download and double the amount of space taken up by third party software?
x666x
Jan 24, 2008
443
Naw, that symlink is just like a detour sign for your data. You're not actually doubling up.
The only reason I didn't blanket the entire folder like you did was to keep things on the safe side in case I had to track down any problems later on for some reason. I'm just turning on what I need basically.
Jun 7, 2007
545
Queens, NY
can you tell me how to create a symlink so i can get some of my various programs to work also... please step by step....thanks..
blacklabel775
Jul 5, 2007
62
I only know how to do it on a Mac, if you have one of those things then i can help you. If not someone else will have to step up.
x666x
Jan 24, 2008
443
Well, if you install Terminal, you could do everything right on the phone!
blacklabel775
Jul 5, 2007
62
True, you should handle this one 666... after all you taught me everything that i know about symlinks.
