'Sync Books' sends 'Video' size to 11.2 GB
uRabbit
Jul 13, 2009
249
Have 3GS set up to sync. If I select 'Sync Books', the Video size shoots up to 11.2 GB. And, I have no books selected. What the heck?
Sandrine
Jun 30, 2011
Hi, already experienced some strange things with my iPhone, but this one is new ;) First thing to try: Reset. If this doesn't help, verfiy that you're using the newest version of iTunes and iOS. To sync books, iBooks needs to be installed on your iPhone. You can also try the iPhone troubleshooting assistant from Apple. If you didn't already try all of these, I hope there's one that does the trick.
uRabbit
Jul 13, 2009
249
Turns out, it was iTunes U sending the Video amount so high. But, for some reason, even checking a new audio playlist to be sync'd sent the video up so high. But yes, it was iTunes U.
