sync with entourage
pemarsh
Jun 5, 2007
93
I really hate ical. I would rather not have it at all. But I am using it to sync iPhone with entourage.
Is there anyway I can sync with entourage (contacts, calendar, etc.) without ical being involved?
tdefriez
Jul 2, 2007
139
Not yet
It only works with iCal involved as a sync conduit, but the involvement of iCal is invisible. Just set Entourage preferences to use sync services (under preferences), open iCal once (seems to need this to work), plug in iPhone and select all contacts under contacts and only Entourage under iCal sync (you have to select home and Entourage to enable you to select only Entourage) and then sync iPhone. It works well baring the lost of categories and projects.
