syncing back to Entourage
want_26
Jun 4, 2008
I was wondering if there is a way to get Entourage to sync with the information I change on the Calendar using my iPhone. I can get the information i enter in Entourage to sync to ical, my "me" calendar as well as to my iPhone. So far I don't see any way to get Entourage to get the information from these other sources.
any ideas.....
Ohmster
Jan 26, 2008
533
21
SoCal
Sure, go to Preferences and Sync. There you designate which calendar and which contact group to sync with ical and AddressBook. Then in iTunes make sure you include them in the sync. Or you can use .me at this point.
Entourage uses sync services to sync with ical and AddressBook. It does not sync directly via iTunes.
