Syncing / Connecting Issue with Vista
Farani
Jul 9, 2007
42
Is anyone else having this problem? I cannot my iPhone to my comp, and you know that chime the iPhone makes, well my phone will connect and disconnect about 10-15 times in about 30 seconds and chime over and over again. Or there are times it won't do that and then it will connect fine for a minutes and then it will disconnect randomly. I then cannot get it iTunes to recognize it. All of this and my phone will not connect USB 2.0. All of my other devices will. Anyone else experiencing a similar problem?
Farani
Jul 9, 2007
42
I think I may have found a solution. Go Run -> MSConfig and then go to startup programs. Disable anything iTunes in there. It seems to have solved my problem for now.
