Syncing contacts
Wilzer
Jun 27, 2007
I will be using my iPhone primarily from my home but really need to sync my contacts a work computer (outlook...which is supported) Will the iPhone be able to be used in this manner? Will it erase my home contacts when syncing work contacts? Thx for any help
ew456
I would love to know if anyone has tried this. I have not tried, but I would think that it would limit us to only syncing to 1 iTunes (1 computer). I understand why they don't want to have the IPOD section of the phone sync with multiple song libraries, but who cares if people get contacts from someone else.
Ljp
Jun 30, 2007
30
I just got back from the office and synced contacts so it can definitely synch to 2 iTunes, different options to sync. My calendar and contacts are on the office computer so I synced from outlook. I keep music on home computer.
The only thing I had to do was when I first connected to my office computer, I canceled the sync (you can do that using the slider on the phone) to keep my music which unchecked everything in iTunes. Then I went back in and check off the syncs I wanted to happen, hit apply and voila. Good to go.
At home I have the sync to outlook options not checked.
I let it just write over everything because I've always kept everything in my office outlook, but there was an option to check that let it overwrite what was in my address book. I assume if you don't check that option, the home contacts might be kept. There are also differnt folder syncing options? Perhaps keep two folders, work and home and sync them to two different computers?
