Syncing email
jjk454ss
Sep 27, 2007
45
OK, I have 3 email accounts that I use on my Mac with Mail. I check 2 of them on my iPhone, but I don't want the 3rd one on my phone. Everytime I sync though, it syncs all 3 accounts. Is there a way to make sure it only syncs the 2 accounts, not the 3rd?
electoman
Sep 20, 2007
127
Atlanta, GA
Under the info tab of iTunes, there is section for Mail. Select the accounts you wish to sync with the iPhone there. I believe that works. I set the phone up before I got the MacBook.
jjk454ss
Sep 27, 2007
45
I will give that a shot when I get home, thanks.
madia
Jan 3, 2008
I use a gmail account in both my iPhone and Mac Mail but I cannot seem to get them to sync. I've tried to use iTunes but no success. any ideas?
thanks,
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Thanks, I'm fairly new at this. can you suggest which settings to adjust?
bill
Open up gmail on your computer and enable IMAP.
Gmail>Settings>Forwarding and Pop/IMAP
In IMAP Access, select Enable IMAP
Now set up your gmail as an IMAP account instead of POP3 account in your mail settings on your phone.
I'm not sure how you're going to get your macmail to sync like this, but if you can set it up as an IMAP account, I'm sure it would be very similar.
I just forward all my POP3 accounts to my gmail account. That way I only have one to look through (other than my Exchange account from work).
Hope this helps.
