Syncing iPhone with PC
Winny46
May 19, 2009
Could someone please tell me if it is possible to partially sync the iPhone ie only the Calendar? My daughter (who is not here right now) setup the sync process and I have no idea how to change the options - or if it is possible.
Thank you.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Yes, you can pick and choose what to sync. Just go into iTunes when your iPhone is connected to the PC, and go through the various tabs covering calendar / contacts / pictures / music / podcasts / videos / applications etc.
Check those you want, un-check those you don't ...
Dec 17, 2008
592
PA
Yes but that will wipe the other stuff out won't it?
For example if you choose not to sync music doesn't it clear your music out? That what I seem to have happen with my pod casts and stuff.
