syncing iTunes 9.0 to iPhone 3GS 3.0
nagyg
Aug 2, 2009
65
After installing 9.0 sync gets stuck at syncing contacts with Windows Address Book. After I disabled contact sync it got stuck at syncing the calendar with Outlook 2007. Once I disabled that as well it would continue with syncing applications and finishing the sync ...
nagyg
Aug 2, 2009
65
after installing 9.0 sync gets stuck at syncing contacts with windows address book. After i disabled contact sync it got stuck at syncing the calendar with outlook 2007. Once i disabled that as well it would continue with syncing applications and finishing the sync ...
looks like you need to run 3.1 on your iPhone to sync with iTunes 9.0 ....
nagyg
Aug 2, 2009
65
Other folks seem to be syncing just fine with iTunes 9 running 3.0 on their iPhones.
Hmm ... do you sync a 3Gs?
I just went back to 8.2 and everything seems to be working fine again, so it was clearly 9.0 that caused my problem ...
