Syncing my iPad to new MBP
bballrob
Oct 11, 2009
1,930
479
Alaska
OK, so I've got my new MBP all set up. And I think I'm ready to synch my iPad and iPhone to it. WHen I was setting up the MBP, the only thing I transferred directly from my old computer to the MBP was my music and movies library. Or so I thought. But I also see now in iTunes that all my apps are in there as well.
So, if I hook up my iPad and iPhone and sync them, will everything sync properly? I just don't want it wiping everything off of them and having to start from scratch if I don't have to.
Josh Yates
Jul 14, 2007
563
32
Orion, MI
I've never had a problem. If, for some reason, iTunes is going to wipe your iDevice, it will ask you if you wanna sync with a new library and it will erase current content. If that happens...well, you pretty much have to sync with the new library. At least that's my experience. (Only other solution is restoring the MBP from a Time Machine backup.)
