Syncing Notes
doron
Apr 17, 2007
1,141
tampa, FL
...i have quite of bit of notes that i typed in my phone...when i sync, does my notes sync as well? thanks.
Make sure you have "Sync with Selected Accounts" enabled in iTunes under the iPhone. And of course, you have to be running Leopard.
doron
Apr 17, 2007
1,141
tampa, FL
thanks for respondin'...i've yet to find "Sync with Selected Accounts"...and i'm not runnin' Lep-
Lol. Yeah. Gotta have Leopard. Sorry.
Swagfndr
Jul 30, 2007
22
Laguna Heights CA
I am running leopard but can't find the "Sync with Selected Accounts" button, Probably looked right at it and couldn't see it. Any help would be great. I use note and to-do's a lot.
lectioneer
Is anyone aware of an application that will allow me to sync "Notes" of either 1st gen or 3g iPhones?
doron
Apr 17, 2007
1,141
tampa, FL
I just E-Mail them to myself.
same here...but it would be nice to add that to the roster syncing notes...you think they would have had that on lock by now...
thehotrod
Jul 30, 2008
37
I use Evernote to keep track of all my notes on all my machines.
pattirj67
Mar 10, 2009
On the Apple website says you can synch notes from the iPhone to your mac with the update today.
I do not know where notes are on the mac....anyone?
FuelieNova
Aug 3, 2008
636
33
It says mac or pc.... I haven't be able to find it on my pc either.
Tg
PDACPA
Jan 16, 2008
542
Go to the Info Tab in iTunes with your phone plugged in. Near the bottom is the sync notes.
Funny thing is that Mobile Me does not give you the sync option for notes on the PC.
ejmonkey3
186
on a mac there located in mail, under reminders tab, WHOO WHOO 3.0 kicks ass, cant wait for 3gs on friday!
steeler
Sep 26, 2007
82
Does anyone know if notes syncing is up and running? I can't get mine to work. I have it turned on in my iPad and iPhone.
steeler
Sep 26, 2007
82
Yes, if I type something on my iPad in notes it should sync to my iPhone
iphonewarrior
13,847
702
That's not wifi syncing. That's iCloud :)
Make sure you have enabled iCloud on both of your devices and it'll sync randomly when your devices connect to a wifi network.
Thread moved to the iCloud section.
steeler
Sep 26, 2007
82
I have everything set right and it doesn't work. Everything else, calendars, reminders work fine.
steeler
Sep 26, 2007
82
Still can't sync notes between iPad and iPhone in iCloud ...sigh. Any suggestion? Anyone?
