Syncing one application only
JLP75766
Jul 10, 2007
Is it possible to sync only one app instead of having to sync every app every time. On my first iPhone Synching took about 5 minutes, now it takes over 1 1/2 hours (I am an app junkie). If I don't check sync selected apps it wants to dump every app that is not checked. My apps don't change, why do I have to sync every app EVERY time or lose them?
Any help would be appreciated!
Sirius389
Oct 1, 2007
98
New Jersey
to pick which apps you want you check selected apps in the Applications tab on iTunes, then it will only put those on the phone, just uncheck the ones you don't want on there and iTunes won't sync them
showguy
Dec 2, 2007
769
Long Island, NY
I think he wants to maybe just sync new apps as he gets them or gets updates. If you uncheck the boxes he will erase the other apps.
