Syncing songs from from someone elses iTunes
redneck47441
Jun 3, 2009
120
My old computer crashed and all my music was lost I was wandering if it's possible to take some songs from my moms iTunes and put them on my phone? Also if this is possible is it also possible once there on the phone to sync them to my iTunes account thanks in advance?
ashwini
Jun 2, 2009
334
India
www.ashwini.co.in
You can sync your iPhone from 1 computer only. But you can sync as many as 5 iPhones to a single computer. And, you cant transfer music from an iPhone to your PC/Mac. It only works one-way.
BDB
Jun 14, 2009
I need help with clearing up the duplicate songs. I download from iTunes, so there's no typing errors of titles or artists - I'm so non-tech. Please make this as understanble as possible....it's driving me crazy?
redneck47441
Jun 3, 2009
120
So I just download it onto my computer and then it will tell me to plug In my device and then I just upload them to that site and then drag them over to iTunes correct.
juice95
Jul 15, 2009
Do you need that on both machinges or just the one you are moving the files to?
This may be a totally different forum topic, but I am new to iPhones/iTunes. This is a related issue so please be kind...
I have music and vids on my Home PC, My Laptop and my Work PC
I have done the whole "set your iTunes to Manually manage"
but it still says that it must erase all the lists, etc. to "sync" with the other PC
is the NO way to load a single playlist with songs/vids from multiple PC?
ALL are authorized
I am bald from puling my hair out on this
iNinja
Aug 8, 2008
3,984
20
UK
Yes, just download a program such as Ifunbox and then when you plug in you iPhone / Touch / iPod it will display it in a device list. Click on your device and then you have options for music / video / pics etc and you can highlight them all and then just click the copy to pc option. Really easy
ALL are authorized
Yes, you should be able to do that, I think aswel as clicking manually manage music you need to click on the "only sync checked music" option.
If this doesn't work, it may be a bug (known or otherwise). In the meantime could you not merge your libraries?
