syncing w/ Outlook Business Contact Manager
Jakeyw
Jan 16, 2008
I am interested in buying either an iPhone or an iPod Touch, but first want to make sure it will be able to perform the functions I need. I am using Windows XP pro sp2, with Outlook 2007 with Business Contact Manager (which I know many people do not have or use). Does anyone know if there will be a problem syncing my businesss contacts to an iPhone or iPod Touch as a result?
Thanks!
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Thanks!
I have the outlook 2007 Professional and it works really well with my iPhone.
Jakeyw
Jan 16, 2008
Yes this has everything, with the businesss contacts, access, excel, groove, infopath, one note, outlook, powerpoint, publish and word.
Great! Thanks a lot!
Next Q: There is a $40 price difference between the "new" iPod Touch and the old ones in stock at Tekserve. I understand that there is a $20 update that is needed for the old ones, but is there any other difference between the two?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
The diff is the new ones today have that update shipping with the new ones. So the old ones have to pay the $20 which I think sucks.:mad:
Jakeyw
Jan 16, 2008
It does - its one of several reasons that I will not be switching to a Mac. They seem to have to upgrade their OS every 15 minutes.
But back to the Touch - there is no hardware difference between old & new? Better screen? better touch recognition or anything?
stobstar
Oct 21, 2008
synching Business Contact Manager with iPhone
hi....i just got my iPhone last week and still have not figured out how to synch it with Business Contact Manager to where I can look at Accounts and Business Contacts info.
Could you please explain how to do this?
thanks so much,
eric
saradove
Dec 14, 2008
thanks so much,
eric
Hi, I'm thinking about getting an iPhone and also use the Business Contact Manager part of Outlook 2007. Did you ever get yours to sync right?
Does anybody know how to do this? Thanks in advance.
hotelspy
Jan 19, 2009
Syncing iPhone 3G with 2007 Outlook w/ Business Contact Manager
I own a 3G iPhone and currently you are able to sync the iPhone with Outlook as long as you aren't using Business Contact Manager. The setup to sync your contacts in iTunes does not support Outlook w/ Business Contact Manager. I had to downgrade to just using Outlook without the Business Contact Manager add in for it to work. =(
This would be a great app for someone to build for those of us that use the Business Contact Manager add in with Outlook.
arneo
Jan 12, 2009
Syncing with Outlook BCM (Business Contact Manager) simply won't work with iTunes.
This is because the information is stored in a central database and
does not act like a regular contact / projects folder that is sync-able.
A work around is to copy the "Accounts" and "Business Contacts" to your local Outlook (or Exchange) in separate folders and sync those folders.
While adding information to the contacts syncing them back to your BCM, will be a problem.
And I don't have found a solution for that.
Ciao
kadeschs
Jan 16, 2009
Not surprising...a lot of things aren't supported. LOL
