This is the way to make t-zone work for t-mobile...
has anyone tried this? can someone temme how to upload the file when he says... got to /private/var/root ? and upload this file...
way how to work on t mobile edge settings you don't have to touch any edge or apn settings well my Internet is working t mobile zone connection 5.99 for t mobile users
1. explore your mobile and under
/private/var/root
you need a to copy a file called "proxy.pac"
create a file by opening a notepad and cut and copy this code
function FindProxyForURL(url, host)
if (isInNet(myIpAddress(), "10.0.0.0", "255.0.0.0"))
return "PROXY 216.155.165.50:8080";
else
return "DIRECT";
and name it as proxy.pac
PLEASE DO NOT TO SAVE THE FILE AS proxy.pac.txt but proxy.pac
and upload it at this
/private/var/root
(if by exploring your phone you don't see the change in file name ,download mobile finder on your mobile through ibrickr and rename it on your iPhone itself....)
After Copying download the file below
http://rapidshare.com/files/55487664...ces.plist.html
and go to
/private/var/root/Library/Preferences/SystemConfiguration/preferences.plist
JUST OVERWRITE THE FILE WITH NEW ONE YOU DOWNLOADED FROM RAPIDSHARE
don't NEED TO TOUCH EDGE SETTINGS OR APN SETTINGS AND THEN REBoOT YOUR PHONE
HERE YOU GO CONGRATS!
MINE IS WORKING WITH T MOBILE 5.99 t-zones plan and its pretty good speed
CHECK YOUR SPEED BY OPENING THIS WEBSITE ON YOUR iPhone
http://iPhonenetworktest.com/iPhone_network_test
mine is 143.61 kbps wats yours/////////?
